So I already have my Sony XAV-622 head unit, Sundown SA-12D2, and Hifonics BRX1100.1. I have the Mach 460 system in my car, but that's all coming out and getting replaced with the orders I got in the past couple days.
So far I've stripped out everything except the factory rear speakers, amps, and wires. I have removed all of the panels necessary, front speakers, and my head unit.
Here's what I got in:
Got everything in. I'll follow up with a list of what exactly it all is. Totaled around $1200.
9132600D-0570-4A92-B072-FC6BB95B5579_zps
DF9EEFBB-D4CA-48C1-8339-6E780303CFCF_zps
5639746E-0488-44DD-87E2-B5D8D536B18B_zps
CF65CED1-16E2-4073-B28B-B802DE6F84CB_zps
BEE3E413-0CC2-4E31-B890-001C444FA5FB_zps
868A9263-123D-44DE-8BFF-25BCC5B44A45_zps
XS Power D3400
SHCA 1/0 Power/Ground (20/8 ft)
SHCA 4 gauge Power/Ground (10/each)
2x20ft SHCA RCAs
40ft SHCA yellow remote wire
20ft SHCA black remote wire (radio ground)
T-Spec 1/0->2x4awg distribution block
SHCA 1/0 and 4awg lugs (10 each w/ black/yellow heat shrink)
Black/Yellow "Safety Stripe" TechFlex 25ft for 1/0 and 4 gauge
Hifonics BRX320.4 (bridged for front speakers)
Sundown SA-6.5CS components for front
50ft SHCA 14awg speaker wire
25ft SHCA 12awg speaker wire
SHCA waterproof ANL fuse holder (yellow logo) w/ 300A fuse
XS Power 580 battery terminals
2xStinger Digital Voltmeter (one at battery other at sub amp)
NVX 40ft^2 sound deadening
14 Nakamichi Banana Plugs
15x4ft Black carpet
5M RGB 5050 LED strip
Music Controller and remote for LEDs
Box terminal to hook wire into
and gloves, i see that bloody finger print.
i used small screw driver to press down and roll back and forth. then borrowed a friends roller and it made a little difference to the eye on how well attached it was.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yeah didn't expect it to be sharp and then I gashed open my middle finger. Surprised me how much it was bleeding.
Do y'all think this will make a good difference? It's 40ft^2
i would have started with either the trunk or front doors. doing the trunk helps minimize rattles from the subs and doing the front doors help with sound quality upfront. 40ft of it should make a noticeable difference though.
making sure its on there real good will help to though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
