6 e12 sundowns walled in monte carlo
Blake Farrar
if you're putting it int he back seat don't half ass it. Wall it off. I'd imagine you can get away with a much smaller box for 2 18s than 6 12s but I'd have to look. That may be possible outside of the car I don't know. then once in you would need to trim it off.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I agree, the box for 2 18s could potentially be built outside of the car, slid in, then you could do the trim and sealing off panels once the box was in the car. That might be a good idea. A couple of those 18s will need like 14ish cubes and then the port displacement, so it will be a big box, but still might squeak through the door opening. Get some measurements, width, height depth, one of us can do a quick design for the18s, maybe you could make a cardboard dummy box and see if it fits through the door?
boxes sitting on the back seat will perform horribly
I'm thinking he could make a platform, anchor his box and then trim to seal it off like a wall. That way, if possible, part could be built outside of the car and the rest inside. I don't know his dimensions, I know it will be a heavy bitch to get into the car and wrestle around, if it can be partially built outside at ALL. A 12-14 cubic box will be a two guy lifting project, the way it will have to be manipulated into the cabin. Like I said, that's even if it can be done that way. Without measurements, who knows.
Either down size and do a trunk build or wall it off with the idea you had for 2 18s. & yeah some people may be dicks around here but they are helpful.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Why would you go through all that work for the entry level subs? I'm not trying to jump on you, I'm just curious. Also why did you get the e-series?
the e seriers are amazing i have 2 on 1100 watts and there pretty good i just thought 6 would be crazy but after hearing everyone i think 2 x18s would be a better bet and handle them lows better haha
well if i want to up grade i have to wall or put in the back seats my truck is full with 2 e12s in 2 1.8 cube boxes im just kinda sketched about building a box inside my car cause i really dont want to mess up my car.
thats exalty what i wanted to do ive seen a few walls build like this and it seems alot easier than building it in the car and ill get some measurements latter today.
  • Who's Online   0 Members, 1 Anonymous, 6269 Guests (See full list)
