Any improvements to my wiring? Need suggestions!
So I just want to make sure that I have connected everything the right way. All the green dots are places where wires connect to each other at terminals and such, red is positive, black negative. My jeep has a stupid starter relay that seems to only work if the alternator is wired to it then it to the battery; I think I tried to wire the alternator directly to the battery and another run from the battery to the relay but as I recall it did not work. I don't know why it needs to be this way. I used my multimeter and it shows there is a lot of resistance between these connections. Other than that I think everything else is ok, I might move the amplifier's ground to the second battery but that's all I think I could do at this point.
If you have any suggestions on different wiring methods or places I need to add runs that will improve the electrical greatly that would be awesome.
Fuses are not shown!
F5374DB5-4FDE-4505-A84E-CA308A6870F6_zps
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
i would ground your rear amp to back battery. and have that rear batt close to that amp
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
I do want to ground the amp at the battery, the battery is as close as possible. I have fusing everywhere I just did not draw it. And that is not the starter, it is just a starter relay thing that jeep used in the car as kind of a distribution block, for some reason the alternator cable goes to it before the battery.
that's weird. you'd usually want a power filter (battery) before distributing alt power to electrical components
I know, but for some reason every jeep wireing diagram I find for mine and many other cars is the same like that, it distributes power to a lot of the car's ignition components. I'm wondering if I could just run 2 runs from the alternator, one the way I have it now and add another that goes to the battery, stratifying jeeps wiring diagrams and my resistance concern,
I would go directly to the alternator with the negative and positive then distribute as needed
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
