3 opti1233d trunk wall?
Hammer Knock
if he is doing a legit wall (if he responded yes to the question) I would suggest getting another to run 4-12s
6 12's would be better IMO. 3 12's is like putting a single 18 in a wall lol.
yes 2 for now. opti6000d coming soon. what to do as far as the box goes?
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
and really i need my back seats more then my trunk space. :/
DEH-6400BT
QBOMB 4.5cu
what trunk can even fit 3 12s firing forward with a port? i want that car.
Ford Taurus has a 20.1 cubic foot trunk.
what will i need to power 1 opti6000d? i have a xs 6500 and a stock batt with stock alt right now.
DEH-6400BT
QBOMB 4.5cu
cubes dont matter, you need the width....3 12 thats 36 in then a propper port for it? thats at least 45 inches left to right.
why stick with 3?
do 4 in a blow-through on the 6000d.
fiberglass your entire trunk to make it the box.
t-bolt your trunk lid down so you dont get water leaking past the gasket into the trunk..
Hammerdown... 1%
Cubes matter a lot. You need to quit being so narrow minded and think outside the box, take a geometry class or something. Stop limiting yourself and use some angles. Everything doesn't have to be on the same plane.
  • Who's Online   0 Members, 0 Anonymous, 6242 Guests (See full list)
