Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
I think it'd be more like 4th order tline. lol.
SPL-Lab REPCar: 1996 Honda Accord F22B1 CoupeSuspension: Megan Racing Full Street Coilover Dampener KitAlternator: DC Power XP 270Batteries: XS Power D5100 & D3100Wiring: KnuKonceptz & 2/0 Welding cableHeadunit: Kenwood KDC-MP642UComponents: Hybrid Audio ClarusAmplifers: Lanzar OPTI250X4Subwoofer: 2 Sundown Audio E8.v2Deadener: Sound Deadener ShowdownSPL Meter: SPL-Lab RTA Pro meterWant an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.CA ref: (enellz, 92c1v1c, el_chupo_, Thixx, Kraudio12, SethPhillips, NJack2AF, JamesKarr, ExpoSport, 01 S 10, wgsj_fortvalley, fast306stang, Lakota, blackga, TheLow, adrian1185, the727kid, rudy, sundownz, lmllopez, traksta15, gentlejax, satchel50207, Bigthangs, Goindef154)CACO ref: (extremechevyman67, ghostmechanic, FatBoy2, TheMan007, bdufner, 350zkid, ironb, bmansbach)SSA ref as phi: ( shizzzon, porkchop, onebadmonte, stevemead, TRP, ///M5, denim)SMD ref: (DC Power Rob, Nathan@XSPOWER, Jman08)And then some.
something, not sure
I know Cone + Port firing in to another ported box, is called a "Bandpass Series double tuned Box"
That I think is 6th order quasi
4th order t lines I build all the time, well, usually when I build t lines
It looks just like a folded horn. IMO it sounds best
Ok im going to try making my 12 that's in a tline ill do a ported deal that's to the 12s specs and see how it played because doing it to the 18s its alot of extra wood and work if it don't playout we'll. But ill let u all know on the progress of this as the weeks go by
I can't stop building!!!
4 DC LeveL 4XL 18 Blow Through Re-Build
The newest addition My '97 Ford Explorer Build
My First Build 8 RF P1 12's
My Myspace Add Me
My Facebook Add Me
oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you?
If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up.
looking forward to how it goes goremaster :)
Since you have 4 18's why not something like this? :) Adding some angle to the inner-walls so its narrow at the start and wide at the end would make up for "lack of room" to keep the t-line at the correct size for 4 18's.
Hammerdown... 1%
the reason im not going to do the 4 18's is because im not going to recone them and if they blow have to take them out and recone again... i also work at a audio shop and im going more towards all rockford product. and if i do that its going to be maybe 4 t1 10's or 12's or 2 t2 12's. the main reason i dont want 4 18's is the weight. i've droped from close to 400miles a tank to 260miles with how it sits now. and i believe 4 t1 10s would look sexy how im thinking on doing the mounting of them. plus i would only need one 2500bd and i'd use 2 kinetic 2000 batteries so it would drop almost 500pounds
My Myspace Add Me
My Facebook Add Me
I think there's an issue with your truck if you lose that much mileage.
Hammerdown... 1%
lol i now have about 1000+ pounds that i hall 24/7 and i drive it daily. its only a 1500 2wd, it wasnt ever made to hall that all the time. the ass sits about 4 inches lower then the front all the time now
My Myspace Add Me
My Facebook Add Me
You're spending too much time idling/reving and doing demos :P
Hammerdown... 1%
I'm planning on using a 4" subwoofer to build a t-line. I think it's fs is around 52hz; because this is higher than the fs of most woofers being used in a t-line, should I tune it higher too? Or should I still tune the box to my desired frequency? Right now my box would be 8.3 ft long with a "port" area or 15.2 sq in, which seems pretty fricken big for a 4" woofer.
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
  • Who's Online   1 Member, 0 Anonymous, 1342 Guests (See full list)
