Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Here is my try at a bandpass T-line
I dont know how to calculate tuning for a sealed enclosure, i tried torres calc, but it wouldnt show any tuning only net volume
T-line tuning = 32 Hz
T-line Volume = 4.60 cuft
Sealed Volume = 1.37 cuft
Total Dimensions = 35.25 wide x 23.5 deep x 16.5 tall
Sealed Dimensions = 28 wide x 3 deep x 15 tall
Here is pic before i made the wall to complete the sealed section, it shows where the subwoofer will be. it is double baffled because the sub needs 6.5 inches of mounting depth and port is only 5 inches wide, depending on how snug the sub is I may make a little mounting ring to give it a bit more space.
sealed wall up
top view showing the line and sealed sections. the line is 5 inches wide all the way through even at the 45s
what the finished box would look like, good luck the sub,
Looksgood. Line looks long and sealed to big. Try and get BassBox6.0. That can calculate peak freq in a sealed box
well the line is 106 inches long, which give it a 1/4 wave of 8.83 ft and full of 35.31 not sure how I could shorten it, if it is too long
i recalculated t-line volume as I forgot to adjust it when i changed subwoofer placement, i could move woofer placement closer to the port opening, i have about 15 inches i could work with there, if measuring from center of woofer placement to start the line
actual tline volume is 4.6 cuft
after the first bend, the port actually widens to 6 inches, I need to adjust that back to 5 inches, the math was done with the right numbers, just accidentally made that part 6 inches when modeling it
Got bassbox pro 6, F3 of the sealed box is 142.1 Hz according to bassbox and according to the plot, it looks like the peak is around 54Hz
I got that by putting in all of the driver info as well as box internal dimensions
First off: GREAT POST, thanks a lot for this.
Could someone please explain the 1/4 wave theory to me?
I think i'm in love.. :)
Snowdrifter.. start here: http://www.quarter-wave.com/
Hammerdown... 1%
  • 4 weeks later...
hey man, i was wonderin, what would an t line enclosure b for my alpine type r 10" duel 4. if i can, id like it tuned so i could hit the last note on "Put On". ;) or at least sound wicked on tech n9ne"s song "deamons" off of his K.O.D. cd. thanx
Bring on the Rockfords!!
So, i'm looking for some input..I've got a 10" McIntosh MS468.
The specs I have on it are...
20hz is a long port -_-
The port opening is 3.44x16.25. It is 149 inches long...tuned to about 23hz. The SD is right around 55sqft
The over all box size is 40.5 wide, 20.5 deep, and 17.75 tall. The shape should fit my 97' maxima nice and snug.
Am I doing this right?
whats with the big open spot on the back?
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
