Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Just thought I would share a tline I built for a guy on the weekend. I dont really build boxes any more, but this guy came back to me after a couple years in hiding, I couldn't say no...
Just one of my FLC 10"s Usually about a 500-600rms subwoofer. Being ran at 2ohms on a Hifonic's 1000w amp- seeing about 750rms.
Quarter-wave tuned to about 40hz, but plays well below. Installed in a 95' Jeep Grand Cherokee
^ Notice the slight angle to the line. I still wont say its quite a horn, but I guess you can. Starts off about 45sq inches, ends about 70sq inches.
I build my t lines this way because they seem to handle more power, and play more accurately
Finished.
To make the woofer fit, I had to grind out about 1/4" of the divider in the back
This box sounded great, lows as clean and powerful as a 15" or pair of 12s, and accuracy of a 10" cone.
This time, with this customer, I made sure he got an amp more powerful than needed, so everything can be toned down alot. Gain is low, no boosts in the deck at all, bass, loud, all Zero. Very clean, cone still barely moves 1/2" peak at the lowest freqs
so what im wondering is how do you know what to make the port area of the inside and the outside? do you make the inside start at the sd of the sub and then taper it to make it like 60% larger?
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
beginning is smaller than the sd of the sub. I would say use the sd of an 8" for a 10".. and exit should be sd of 10" for 10".. but i'm just guessing by the pictures ;)
Hammerdown... 1%
Size of exit would more likely depend on xmax specs of the driver used. A high xmax driver could withstand a larger than sd exit easiler than one with low xmax.
Hammerdown... 1%
How far should the port be away from any vehicle wall? My design has 15"x9.25" port mouth but is only ~5" +/- 1" from the sidewall of my jeep when pushed against the opposite wall. Is this distance good enough?
In short, no.
In practice, maybe.
Hammerdown... 1%
output at or above tuning might get a bit of a peak to it, subs will handle slightly more power. Thats about all.
Hammerdown... 1%
Im trying to find a design for a sub up, port back, T line.
Has anybody every done one?
I mean in know how to do it, but will it work to its "optimum" level?
The sub would be laying flat with the cone pushing the waves horizontal, but the port would be coming out vertical.
will that screw things up?
I really only want sub up, port back for the look Im trying to get.
I plan on using 2 RF HX2 10's or 2 RF HX2 8's if I can ever find any for sale
  • Who's Online   0 Members, 0 Anonymous, 1754 Guests (See full list)
