Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
should be ok with them both in the rear deck.
dont think isobaric would help a t-line much
Hammerdown... 1%
"Isobaric - Bass Reflex
If space is at a premium or just a smaller enclosure is desired, an isobaric design may be used. The volume of the enclosure wil be approximately half the space of the above enclosure with the same results. The downside is you will need two woofers vs. one and the output will be the same."
Has Anybody Ever Tried it?
I really want to do a 2 10 box, like the one done at the very beginning of this Thread.
But I just can't fit something that big.
But if I did one like Forevrbumpn built for the Jeep Grand Cherokee And I add a second a sub to it... whats the worst that can happen? Could I hurt something? Or would it just not sound right?
A t-line requires a lot of space. Using two drivers couple together would not improve the performance significantly. If you want to save space just put both subs on the t-line separately. It will get more output than an isobaric setup and probably be more musical than one as well, and have better power handling.
Hammerdown... 1%
I have a question, Im interested in trying a t-line for an 8" I have sitting at the house. But the QMS is 14.5 and the QTS and QES is .6
Thats alittle bit higher than what was recommended by Forevrbumpn, will this effect much?
your sub will probably have a high peak at it's fs instead of having a flatter response.
System:
Basically Stock
In process of upgrading
I realized its F/S is 49 hz =/
Im not to thrilled about that. But if I tune it to its F/S, what kind of sound should i get?
Ive got the whole thing planned out, I may even build it just to see how it goes (since its my first one) but Im j/w what I should expect out of the little guy.
49 hz isn't tooo bad imo depending on how low you want to go & what you listen to. I built a t-line with a cheap pyle 8" at it's 60 hz (fs) it doesn't like rap but sound alright with country & some rock. So might at well try it & see.
System:
Basically Stock
I like low and SQ, I listen to everything except country.
Its a Polk Audio sub I pick up super cheap a while back and I have extra wood laying around. So I figured I might as well try a t-line out and see what it does.
Thanks for the help man, when I start working on it Ill through a thread up in the Enclosures area.
Ok so I finished my transmission line for my elemental designs 13kv.4 (Image Dynamics build house) and I have to say I'm extremely impressed with the performance of it. Granted I build the box right at the Fs of the sub (I believe it was 21hz) which gave me about a 5cf box. Anyway this thing get low indeed but I notice the upper ranged bass still was a bit less to be desired. So I'm wondering if I build a second line and instead of tuning at the Fs of the sub I go to around 35hz - 40hz will get increase the upper bass range output while still keeping some of the lows? Thinking the line instead of being almost 13ft long would go down to around 8 to 9ft, and I could use acoustic filler to stuff the line if need be.
Edit: Let me know if the pictures don't show
2007 Chevy Suburban LT1
Pioneer AVH 5700 DVD
Diamond Audio D3 6 1/2 components
Kicker 06ZX650.4 amp
Kicker 06ZX2500.1 (x 2)
DC Sound Lab Level 4 18's with Level 5 coils
Autotek Mean Machine 400.1D (replaced)
Soon to come:
rims
body kit
flow master pipes
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
  • Who's Online   1 Member, 0 Anonymous, 1884 Guests (See full list)
