Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
I'm probably gonna be building one of these soon, and you said to make it off the Fs of the sub. For me that would be 20 Hz. What exactly does that mean though? Does it get "loudest" at 20 Hz?
Also
For the line that's 37 1/2" long, where is the left end measured from?
the darker line is the wave line itself and the 37 starts in the middle of the sub not the end of the wall seeing the sub isnt positioned there
I can't stop building!!!
4 DC LeveL 4XL 18 Blow Through Re-Build
The newest addition My '97 Ford Explorer Build
My First Build 8 RF P1 12's
My Myspace Add Me
My Facebook Add Me
oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you?
If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up.
  • 3 weeks later...
anyone ever seen an 18" solo-x in a t-line?
Hammerdown... 1%
  • 4 weeks later...
Here is a few t-lines I made recently, the first one was for a dc lvl 4 15 and the second one is for a re se 12 i believe
NOTE: my first time using google sketch up for the first one, and the second one is my second time using it. The first design is nice, but would be complicated to build. Second one woudl be much easier and I just realized i forgot the 45s in the second one, but thats an easy fix.
For the first one, sub is up and port is back, port is directly under the sub
Quaterwave Length: 11.35 ft
Full wave: 45.4
Tuning: 1130 / 45.4 = 24.8 Hz
Port Length: 135 inches / 11.35 ft
Port Area: 135 inches
Outer Dimension Volume: 15.64 cu ft
Inner Dimension Volume: 12.61 cu ft (before 45s considered)
Total Volume: 10.55 cu ft(after 45s considered)
Dimensions: 39 deep x 33 wide x 21 tall
For the second I did not lay the info out as detailed as i did for the first one, but here is some info
Port area=104 sq in
Port length=111 in
tuned to 30.5 Hz
those are huge 45's..
Hammerdown... 1%
Here goes my first attempt at the t-line.
2 JL Audio 6W3V3-4 6"
Free Air Resonance (Fs): 41.80
Electrical “Q” (Qes): 0.533
Mechanical “Q” (Qms): 11.027
Total Speaker “Q” (Qts): 0.508
Equivalent Compliance (Vas): 0.181 cu. ft. / 5.13 litres 0.178 cu. ft. / 5.04 litres
One-Way, Linear Excursion (Xmax)*: 0.35 in. / 8.89 mm
Reference Efficiency (no): 0.067% 0.062%
Efficiency (1W/1m)**: 80.49 dB SPL 80.13 dB SPL
Effective Piston Area (Sd): 17.36 in. sq.
Thermal Power Handling (Pt): 150W 150W
19"sq x 2 port its a little bigger than the 17.36 listed
Tuned to 37hz
I bought these for the doors to bring some bass up front but thought i would try the t-line first.
So i wonder how these are going to sound?
Im hoping they arent a 60hz 1 note wonder
those have fairly high Qms for a t-line and high qts, so im not sure how they would sound, normally youd want a qms under 7 and qts under .4 or as close as possible of course
the design itself doesnt look bad though, I dont know how much having the port area a bit larger affects it, but i dont imagine it would be too bad since its not much larger
lol, yea i know, but it keeps the 15X9 port all the way around
extend the inner wall a bit and make them smaller, you get a more rounded corner that way and gain a couple inches of length without making anything larger.
Hammerdown... 1%
cool, i will try that, thanks
  • Who's Online   0 Members, 0 Anonymous, 1189 Guests (See full list)
