One Subwoofer Not Responding to Lows.
Exscathe
Can you tell us about your box?
yes tell us O.O
what 2k amp btw
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
I would like to see vid of subs playing
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
It sounds like the guy knows what the wiring side of things is. But I still want vid. Sounds like out of phase.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Wire comes in from the positive of the amp to the positive of one subwoofer coil, then the negative of that same coil goes to the positive of the other coil, then the negative of that coil goes to the positive of a coil on the other sub, then that negative goes to the other coils positive and that coils negative out to the amps negative.
His wiring sounds right. Visualize it.
It doesn't hurt check final load with a DMM and do a pop test just to verify things though
I did check final ohm load and I got 2.8 Ohms roughly, +/- 0.1 ohm because subs are dual 0.7 ohm. And can someone tell me how to post pictures on this forum so I can put them up.
http://www.stevemeadedesigns.com/board/topic/160056-how-to-post-pictures-on-the-forum-photobucket/
skar sk2500.1
alpine HU
2 x-15 sundowns
  • Who's Online   0 Members, 0 Anonymous, 552 Guests (See full list)
