One Subwoofer Not Responding to Lows.
Exscathe
i don't see why the way you did it wont work but imo just for piece of mind I would wire it like the diagram kranny and sbg posted. better safe then sorry.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
well, then wire to 1ohm and be done with it. get upset all you want that people are trying to help and give you advice. doesn't effect any of us.
4 pages of suggestion and answers and seems like you haven't tried a single one of them. sorry but if your giving ideas and get upset about a suggestion people aren't going to want to help you very much.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I'm with alaskanzx5.
You know it all but can't find your own problem so I'm done with this.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Your complaining on my post that I am not taking the advice given. If you know anything about wiring it does not matter what order you wire it in, take four diodes for example, put them in any order you want as long as polarity is right and they will work as intended. I did take advice given, sorry if I don't wanna change my series wiring to a different series wiring, it should not make a difference, use your head. I am upset my driver is acting like this, not that a few people are telling me to wire in series a different way.
Total Advice Taken:
- Meter the coils.
- Pop Test.
- Examine drivers to make sure polarity is the same.
- Check wiring again.
- Meter total load after wiring.
This is axactly why people hate internet audio people, and Americans.
  • Who's Online   0 Members, 0 Anonymous, 1399 Guests (See full list)
