One Subwoofer Not Responding to Lows.
Exscathe
its all fun and games until real life interjects.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I dunno about others. But if im having an issue with my system. I WILL figure it out that day or night. I need to know whats going on. So i can fix it then, or know what to do the next day. Peace of mind.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Sure go into -20 celsius, in the dark at 10pm at night and use a screw driver (for lack of having a cordless drill) to unscrew the drivers. By the time you get your second screw out, you won't be able to use your phone or handle anything because of the freezing cold fingers you will have. Also cant see the drivers very well in the dark to see if I had fixed the problem.
Well if I ever need excuses for anything I can always start in this thread. I'll have a nice sized list by the time youre done. Next you should probably mention that mom doesn't want you to go outside because a stray dog might drag you away.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You go ahead and pop test on 16V all day, I will use my AAA which will tell me the same thing I want to know without risking damage to the sub.
the woofer barely moves on 1.5v. and you wont blow the coils at 16v....your amp will probably output like 70v.
if you hooked up a car battery that can supply hundreds of amps, then you'd have an issue. but something like a drill battery wont affect shit.
regardless of everything, you'd only have it on power for a split fuggin second.
Amperage is a function of voltage and resistance. Even assuming the battery and wires have zero resistance, each sub would only be seeing ~75 watts for a split second :shrug:
  • Who's Online   0 Members, 0 Anonymous, 969 Guests (See full list)
