RE XXX 15
fx4trucker
is the RE XXX 15 a ground pounder or SQ sub ?.. it hits but not what I was expecting . it does sound really good ..
set up - the box is about 4.88 after displacements and port tuned to 32hz. I have a Memphis mojo 2500 watt amp on it.
going off specs the box is a tad big so I was planning on fixing that soon witch will change the port tune to 34hz
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
How much port area did you give it? That sub has 54MM of one way linear excursion and needs some serious port.
It is an SQ sub though and is a low end monster.
Just so you know, the RE XXX is designed to be used in a sealed enclosure that's why it has so much xmax.
It should be close to a SQ subwoofer, but it still can be very loud.
The port is 5x7x14 ..box is over 5cuft 4.88cuft after displacement
35sqin of port? 5" tall by 7" wide? you might as well have no port area whatsoever with that small a port.
need more port, id say about 70sq in maybe more.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
What about just doing a sealed box ?
It will do just fine in a sealed box, it will be very loud for a sealed box because of the high xmax.
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
