Jessica Posted February 24, 2014 Report Share Posted February 24, 2014 The positve output is on the master amp. Just dd1 that amp while they are strapped and you should be fine. Just don't use track 7 Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Jessica Posted February 24, 2014 Report Share Posted February 24, 2014 Yes my amps are strapped Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 24, 2014 Report Share Posted February 24, 2014 Your last reply to me answered your own question then lol Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 24, 2014 Report Share Posted February 24, 2014 I would dd both of them though. Find out which amp has the lower voltage out clean and use that as my master. If you have the higher voltage as your master you may cause the other amp to put out a slightly dirty signal. It probably won't be much but if you are going through all that trouble might as well cross the ts and dot the is Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Jessica Posted February 24, 2014 Report Share Posted February 24, 2014 (edited) True, but unless you use the 0db tone you will have overlap anyway and still risk clipping. But n8's idea is smart Edit. I meant to say 0db tone Edited February 24, 2014 by strangeduck Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 The positve output is on the master amp. Just dd1 that amp while they are strapped and you should be fine. Just don't use track 7 quick question here . the amps are the new sundown 5k so when i check the power out from the master do i need any thing else connected to the speaker out ? only reason i asked is i followed the sundown diagram on how to strapp expect i forgot to connect the negative speaker out form master to to slave and the subs went crazy lol. Quote Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 I would dd both of them though. Find out which amp has the lower voltage out clean and use that as my master. If you have the higher voltage as your master you may cause the other amp to put out a slightly dirty signal. It probably won't be much but if you are going through all that trouble might as well cross the ts and dot the is i already did that lol. when i tested the amps single 1 to each sub i set each amp with the dd-1 and to the eye both gains looked identical and when i checked with the meter thy were with in a tenth of each other . and btw i am using track # 3 Quote Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 Your last reply to me answered your own question then lol not really lol. the question was not how to strap but the proper way to set the gains while strapped using the dd-1 Quote Link to comment Share on other sites More sharing options...
corona_jeff Posted February 28, 2014 Report Share Posted February 28, 2014 If you setting the gain on a strapped pair, you treate it like a single amp. The master gain controls both amps Quote Link to comment Share on other sites More sharing options...
