Aero port. Is this gonna be a problem????
coh33dkill3r
I recently built a ported box for my sundown x18 and using 2 6" steel aero ports that I built... Problem is I only have 4 1/2" clearance from the end of port to the wood inside... Will this reduce proper airflow or do I need to be atleast 6" away from the inner wall
I originally built one of my boxes with an up firing port and didn't like the sound. Laid it down port back and don't have the airspace between the port and panel that they say I should have but I think it sounds better. It may also be dependent on power. I recently bought an x18 and haven't built the box yet. Hope it sounds alright for you.
Airflow probably won't be an issue, but it may lower your tuning slightly. I'd give it a try and see, if its not going to be too difficult.
Builds:
It is the minimum diameter that should normally be the distance from the back of the wall. However, it shouldn't be much of a problem other than lowering the tuning and possible lowering the useable maximum velocity of air a little bit.
But as you stated it shouldn't be much trouble to pull them out and shorten them slighly to compensate.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
You should be totally fine on that power.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3064 Guests (See full list)
