Box help for 2 Soundqubed HDS300 12's
walwalka
I'm wokring on figuring out a box for my new 12's and I'm struggling. I have some done up and torres, I just would like to know the thoughts on this one.
First, I have max demension of 34w x 16t x 23d. These are what fit reasonably in my trunk.
I'm really curious how the port are and the port area per foot stack up.
I want an overall good sound and output, I wouldn't be against tuning a little high to 34hz if need be.
Thank you
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
In my opinion, the port area per foot's a bit tiny, especially for those air-hogging subs. Everything's perfect in my book besides that, box might be a touch too big though. Have you considered two side ports?
2001 Civic LX Sedan
Pioneer DEH-7500HD
Big 3 in 1/0 Knu CCA
Rockford P500-4
RF Punch P165-S in doors
RF Punch P165 in rear deck
Front doors deadened with Damplifier
Next
SQ's new HDS208 8" in a T-line whenever it FINALLY COMES OUT I CAN FINALLY AFFORD IT
:dammit:
Bend over and I'll show ya.
how is it 2 days work? half a day at most, i may be an idiot, but im not an idiot.
subs take up a little under .3 ft^3 for a pair if i remember right. make port 4.75-5" wide run subs inverted and add 2nd baffle use wood dowels as bracing. takes up very little space too. that should give u the sound u want
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
Sq said that the woofers were .08^3 each for displacement, so I made the displacement a little big.
There is no possible way to run inverted, they are going in a trunk and that is the space I have to work within.
Here is another version that changed somethings in.
I plan to add another baffle, however I don't want torres to calculate into the external dimensions. I'm going to use some 1 in dowel to brace up the box as well, I added some displacement for that in. What do you guys think now?
The second one looks better but the guys who can help need to know what kind of power your going to put to them.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
They will be seeing 2200w rms from a Soundqubed Q1-2200D at 1 ohm.
Btw Joe is one of the guys that can help so listen close.
80prs
DC 180 alt
0.08 cubic feet? I don't think so.
That is what the email I got back from them said, but if it is wrong I will take your word for because I really have no idea. I tried googling but of course I didn't find much.
I will listen to joe x he designed my current box and I love it.
Updated with more woofer displacement.
Run subs inverted and you will have enough space. 4 cubes is a bit small for them.
  • Who's Online   1 Member, 0 Anonymous, 1582 Guests (See full list)
