Question on my electrical
Ok so I got some skyhigh 1/0 awg CCA and got a battery for the back just another stock battery until I can afford my d3100 but I was wondering and making sure what size fuse for my bdcp 2500 witch will be at 2 ohms doing around 3500 and my TMA 440.4 doing 50 amps i already ordered 2 250 amp anl fuses and a 1/0 awg input and 2 4ga/8ga outputs with a 200 and 50 amp fuses will this be fine ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
250a or smaller fuse on the 0ga
ok will I be fine running them 2 amps on the 250 amp fuse ?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Give me some details. It was hard to understand what you were saying in your first post.
ok so I some 1/0 awg CCA and have already ordered 2 250 amp fuses one for under hood one for trunk battery and a a 1/0 awg distribution block with 2 4/8 awg outputs to replace my cap and was wondering would the 250 amp fusses be ok on the 2500bdcp and my TMA 440.4
Also I'm ordering 2 level 4 Dc 12's tomorrow and was wondering what size speaker wire to use ;)
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Bump .
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
You don't really have a choice but to use a 250a fuse.
That being said, I'd personally want 2 runs of that wire. Run them to a buss bar, then run your amps from there. It's not just about wire ampacity, its about voltage drop too.
Also: don't forget to fuse the wires after your distribution block accordingly
whats a bus bar lol and so 250 amp under hood then battery then 250 amp fuse then dist block
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
If you're running it at 3500 rms like you said, you'll probably blow a fuse somewhere down the line
Welcome to my sig :D
My build on my 2008 Jeep Grand Cherokee Laredo 4x4:
2 Sundown SA 12's
Sundown SAZ 1500d v3
Alpine CDE-HD148BT
Hertz 165 Speakers
Atrend Carbon Enclosure
Stinger SPP925 Battery
Sky High 2/0 & 1/0 Power Wire & Big 3
:domodance::domodance: Legal 145.2 dB. :morepower1: Team Sundown. :domodance::domodance:
cd64929e-8a60-41ea-b784-c5c6096f49b8_zps
  • Who's Online   1 Member, 0 Anonymous, 1808 Guests (See full list)
