boom50cal Posted February 27, 2014 Report Posted February 27, 2014 Okay guys, getting ready to invest some money into my electrical before I get my build started. Just wanted to get some other opinions. Plan is to run a SAZ-2kD 1 ohm daily, 0.5 ohm for fun, and a Zapco 300w 2 channel. Electrical plan is the following: Singer 220a Alt SkyHigh 2/0 CCA front to back, and for grounds Deka Group 48, under the hood Deka 31's in the trunk, 2 of them. My question being, will a single run of 2/0 CCA be enough front to rear? I've heard all this bad shit about CCA back and forth, but 3kw doesn't seem like that much for wire that's as thick as a garden hose... For giggles, ms paint diagram On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
pioneerforlife Posted February 27, 2014 Report Posted February 27, 2014 I think you could get away with the cca but imo since you have a nice alt and nice batts I would go for the ofc. I am planning on running about 4K on stock 140 amp alt and 4 extra batts and I am using cca but I am doing 4 runs of positive and 6 grounds. If you do use cca I would do at least 2 runs to be safe. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
boom50cal Posted February 27, 2014 Author Report Posted February 27, 2014 a little overkill never hurt, eh? 2 runs is what I was thinking too. my whole logic on the deal is kinda based off bighoss's build....nearly doing a 60 and he has mainly cca. thanks for the reply though. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Kyblack76 Posted February 27, 2014 Report Posted February 27, 2014 I think youd be fine. The wattage isnt what your supplying. Your getting your amperage from one place to another. In your case, around 200 amps from the front to the rear. The 2/0 piece, should carry that fine. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
