gibblegeibel Posted February 28, 2014 Report Posted February 28, 2014 ok i asked for help before on this topic. i am getting engine noise out of the ct sounds 60.4, i unhooked the sub amp and upgraded alternator wire from the battery and still have the noise.then i tired disconnecting the rca's for the sub and the remote wire for it as well. i still have the noise. the ground wire on the 60.4 is as short as it can be. here i a a little map of how my wires are hooked up. if it is hard to explain i can help. the remote wires are 14 gauge for the hifonics brutus br1700.1d and 12 guage for the ct sounds 60.4. they are ran together wrapped in wire loom. the rca's are audio technix for the 60.4 and schohe for the hifonics. they too are ran together and wrapped in wire loom. there is about 6 inches between the remote wire and the rca's. the power and ground wires on the hifonics are sky high car audio 0 gauge cca as well the big three upgrade. the power and ground wires on the ct sounds 60.4 is elite audio 4 guage i am not sure if it is cca or ofc. the 4 guage and 0 guage run side by side in the car through the bulk head. then after they enter the car the 0 gauge guys back the driveside to the hifonics. then the 4 gauge goes around the bulk head to under the passanger seat for the ct sounds. the 4 gauge crosses under the speaker wires and remote wire. if you guys need any more help understanding my setup let me know. thank you for your help
deathcards Posted February 28, 2014 Report Posted February 28, 2014 have you tried the battery ground? skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Rich Schenk Posted March 1, 2014 Report Posted March 1, 2014 where are your amps grounded to? On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
gibblegeibel Posted March 1, 2014 Author Report Posted March 1, 2014 the amps are grounded to the seat bolts. no i have not tried the battery ground. what could be done to the battery ground to change it or help?
lightfoot Posted March 1, 2014 Report Posted March 1, 2014 are your rca's ran on the opposite side of your power wire?
Rich Schenk Posted March 1, 2014 Report Posted March 1, 2014 ouch. ground to shock tower or frame. frame if the car has one. get a wire wheel and take it down to metal and put dielectric grease on the connection and you should be good to go. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
gibblegeibel Posted March 1, 2014 Author Report Posted March 1, 2014 they are ran down the middle of the car since i have the power wires running down the passanger and driver side.
Rich Schenk Posted March 1, 2014 Report Posted March 1, 2014 ya also make sure rcas and power are on opposites sides of the car that can induce noise into your system. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Rich Schenk Posted March 1, 2014 Report Posted March 1, 2014 definitely sounds like your amp grounds. try regrounding those first On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
gibblegeibel Posted March 1, 2014 Author Report Posted March 1, 2014 well i can't ground to the strut towers don't have studs exposed on the inside of the car. the does have a frame it is a unibody car. the ground locatations are ground down to bare metal. i have the rca's as far away from the power wires. as i can
