Before Three batteries install important question?
I'm going to install three batteries in my car in parallel. Before I install them I want to make sure that I'm doing it right. I am not going to use a battery isolator because everybody have talked to said do not use one. Now that being said the batteries are going to be ran in parallel all connect together grounded to the front battery. The truck has a big three installed. If I have all batteries connected without a battery isolator and I am not using the system will the batteries become over charged. Or does the alternator know when to not charge all the batteries.
2003 GMC Yukon Denali Xl
Head unit - Sony 701hd / three Powerbass 3xl 12' / Mids -six Audiopipe apmb-6 mid bass,
highs- six Audiopipe atr3721 3 3/4 tweets + two Lanzar super bullet tweets /
sub amp- Hifonics Brutus 2400.1d / highs amp- Hifonics Brutus 640.4 ,
two HC2000 kinetic / wire-Sky high car audio 0/1, 8 gauge, 12 gauge, 16 gauge / 300 amp Ohio gen. alternator
U won't over charge are u also grounding to the frame in the back
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
What does your alt charge at now? As long as it's in the 14.X V range you'll be fine.
Just make sure the fuse your positive run from front to back next to the front batt AND the back in case anywhere in between if the wire rubs through the insulation and grounds out, all your batteries will be saved.
Besides, when in parallel, the alt or anything else for that matter sees those batts as one biiig batt.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Looking at all the diagrams I've seen does the battery have to be grounded in the back of the truck?
N()()b double post
Yes
Thanks for the quick replies
your batts will only pull as much power as they need.
isolators dont do fucking jack shit for a daily system except ruin your alternator faster. only useful for playing music with the car off which no real basshead would do anyways.
edit: only way you can really ruin batteries is by overcharging them 15v+, which wont happen if you monitor your shit.
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
