Next Step (Battery or Alt)?
Looking for some feedback on my next move here, I have searched but it seems like it really is dependent on vehicle/existing mods-
I am completing the Big 3 and running my power/ground wire (Sky High 1/0) in the next 2 weeks in my Impala to power a SQ2200. I currently have a fairly new, non AGM battery up front and a 145 amp AD244 out of an Escalade. I am guessing that I will have a hard time giving my amp the power it needs to run full tilt, although its a DD and I may have enough energy for that (thoughts?). I am thinking I can:
1. Add a battery to the back to try to help smooth out the power and keep the amp happy.
2. Replace the front battery with a better AGM battery.
3. Have the alternator built. I still have the stock alt I could shim and throw on while I have the alt built up.
Turns out somehow I owe rather than a refund, so right now it will be one of the three as a next step.
Thoughts and opinions are welcome!
Don't mix non agm with agm. So don't add a battery to the back. That's my first tip.
second, don't get your alt built up. I've seen alt companies say don't rewind, don't do this, don't do that. they're built a certain way and not good. So if get a new alt, get a NEW alt. More expensive but hey. my 2nd tip.
So either get a new alt, which shall be expensive, or the biggest AGM battery you can fit up front. That'd be my suggestions. Take it for what it's worth.
Sheena = pedobear
IMO, check voltage drop if going down to battery voltage or below get an alt. If staying above battery voltage get a batt if you want but anything above battery voltage is good. a lot of people like staying a above 13v.
Ooh and if say you can make it somewhat through a sing before dropping below battery voltage them a decent agm should help keep you up there longer but at the end if the day reserve doesn't make up for production IMO.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Save up get a quality h.o. alt (mechman DC singer) and switch to agm battery.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 824 Guests (See full list)
