jarrius Posted March 10, 2014 Report Posted March 10, 2014 IMO look in to other brands that are not at your local shops. Ie dc audio Fi audio soundqubed. Also look at Acendent Audio and sundown. Wile some of the brands audio shops sell are good most are way way over prices for what they are. JL audio is a great example of this. Cost way to much money for a sub that does sound good yes but you can get any other brand that will also sound good way cheaper then the W7 you where looking at. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
timc31610 Posted March 10, 2014 Report Posted March 10, 2014 Can you get us your maximum useable dimensions. With that we should easily be able to tell what can fit in your car. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
ChevyBoy95 Posted March 10, 2014 Report Posted March 10, 2014 1. dual 2, so you can wire it in parallel to 1 ohm 2. an amp that does 2000wrms @ 1 ohm 3. no necessarily 4. yes, along with an upgraded AGM starter battery up front 5. Big 3 Upgrade in 1/0 wire, along with 1/0 for the amp 6. If it is in the trunk, i would suggest some 80mil or thick deadener on the lid. 7. no idea, dont live in CA Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Dominick Samayoa Posted March 17, 2014 Author Report Posted March 17, 2014 The dimensions in my trunk are 13 H x 33w x 40 d. The height is restricted because the factory amp and other parts are bolted onto the top of the trunk.
