Man you put in some work on that engine, nice job!
Thanks, im just hoping i can get back to car audio now that its up and running alot better. Paid $500 for the car and i just put about $600 in new parts alone under the hood. LOL
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Haha it know how that goes when parts cost more than the damn car itself lol. But it's a good feeling after you've put in the work yourself and fix it.
Now it's your baby :)
SO I GOT SOME GOODIES FROM DROPPIN HZ CAR AUDIO. GOT A FEW DECALS AND SOME DUEL 8 AWG TOOLMAKER SPEAKER OUTPUTS. REALLY HELPS SO IM NOT STICKING 2 WIRES UNDER 1 TERMINAL AND LOOKS GOOD BUT MAN THOSE ARE SITTING REALLY CLOSE TO EACH OTHER. THINKING I MIGHT HAVE TO INSULATE THEM. GOT SOME SKY HIGH 14 AWG OFC SPEAKER CABLE I WILL BE RERUNNING ALL NEW WIRE TO COMPONENTS AND GET THAT RELAY AND TA4.280 IN THERE.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
I'm really digging those speaker wire inputs! Looking good! :)
Thanks. I really like them! Just worried about how close they are next to each other. I need to insulate them but i want it to look real clean. I plan to try and get some more toolmaker lugs for my amps inputs. Hoping to get my other amp hooked up this weekend i got so much work to do.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
SO ITS NOT THE BEST QUALITY BUT GOT A PIC OF THE GUTS ON THE GORILLA AMP AND FOUND SOMEONE WITH A AMM-1 AND GOT A LITTLE BETTER IDEA OF THE TRUE RATINGS ON THIS AMP. SO IT PULLED A GOOD 1300W @ 1 OHM AND 1600W @ 0.5 OHMS @ 40 HZ AROUND 13V. NOT TO BAD I GUESS FOR A $200 BUDGET AMP.ITS BEEN RUNNING @ 0.5 OHM FOR A FEW MONTHS NOW, JUST TUNED WITH DD-1 AND TURN IT UP FULL TILT, I BET I HAVE PLAYED IT FOR ATLEAST A GOOD HOUR OR SO AND NO PROBLEMS WITH IT GETTING HOT AT ALL, JUST SLIGHTLY WARM.
10636239_747368568654777_121456496776082
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
  • 4 weeks later...
DECIDED TO HOOK UP THE CONCEPT CC-D2400A AND SEE HOW SHE RUNS. THIS AMP GOES BACK 12+ YEARS FROM WHAT I READ. ITS ONLY 1 OHM STABLE BUT I RAN HER GOOD TODAY AT HALF OHM 45/50 VOL 50 BEING FULL TILT NO DISTORTION PER DD-1. SHE DIDNT EVEN WARM UP AND I CAN TELL I GAINED FOR SURE. POWER IS CLEANER. SO THESE ARE THE SPECS ON THIS AMP, NOW THIS AMP WAS UNDER RATED. ITS 1 @ 2400 IS AT 12.XX VOLTS.
2400 watt Class-D mono-bloc amplifier
4 Ohm Power (RMS): 600W X 1
2 Ohm Power (RMS): 1150W x 1
1 Ohm Power (RMS): 2400W X 1
Signal-to-noise ratio: 95 dB
Frequency Response: 5 Hz - 350Hz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 350Hz
Subsonic filter continuously variable from 15Hz to 40 Hz
Built-in phase switch
Comes with Remote Bass Level Control
4 x 40 Amp fuses
1/0 Platinum Connectors
Length: 15.5"
Width: 11.66"
Height: 2.37"
SORRY THE PICTURE QUALITY IS SHIT. DECIDED TO TRY AND USE MY PHONE AT NIGHT TIME IN THE GARAGE. LOL. WILL GET SOME BETTER PICS ONCE I GET IT CLEANED UP A BIT MORE AND GET READY TO START BUILDING A FALSE FLOOR, AMP RACK AND GET THE REST OF MY SHIT FINALLY HOOKED UP.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
BETTER PICTURES OF THE AMP ITSELF BEFORE I GOT HER HOOKED UP. NOW THIS IS A OLD USED AMP BUT ITS WORKING LIKE 10/10. COSMETICLY FOR HOW OLD IT IS, ITS NOT BAD EITHER SOME SRATCHES AND SLIGHTY BEATIN UP ON THE MOUNTING FEET BUT OTHER THEN THAT ITS A GREAT AMP SO FAR. 7/10 MAYBE?
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
