bassman619 04 impala build. 18" in a trunk car
Im pretty sure Its about 18.5 maybe a little more..I gotta get the sub in before I can see what I can do..and yes angled baffle..im sure I can get it in if instead of makin the side of the box the sub is installed into straight up and down I would lean it at an angle that would allow clearance maybe a 70° or 50° angle ..heres a pic for example
You need trunk space to get groceries and shit...bitches love groceries
The x18s cutout is 16.69" and the gasket diameter is 18.49 what I figure is if I have no speakers in the rear deck and seal off holes with foam I should be able to build a big enough box inside the car. Hopefully nobody tells me I cant because that would just make me try harder..hahahha
It can't be done.
Hahhaha..so Im guessing you want to see that work in a trunk car..dnt worry tax check comes in this coming week..
if you go single 18 and show me that it works. I will do it too.
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
Got some more work done yesterday..nothing car audio related but important nonetheless.
Ripping front end suspension apart
Yea I know that tge tie rod ends are shot ill take care of that later. But what I did here was put in new lower control arms. New cv axles. And new stabilizer links.
Also went ahead and did new rotors and wagner thermoquiet ceramic pads. I shoulda took a pic of the old brakes they were shot to death. I didnt even notice they were bad while driving tho. Rotors were badly grooved and pads were almost metal to metal
Il probably paint all my calipers before I put new rims on the car..theyre kind of ugly to me
