Big "3" question
I have searched and found nothing so a quick question and hopefully a quick answer.
I have been recommended to ground my alt case to battery neg. I have 2 options for wire routing. Run the neg around the front of the engine bay (battery and alt opposite sides) or run the ground next to the alt charge wire around the back (shorter distance).
Will running the alt charge and ground wire next to each other cause any problems? I am using 2\0 welding cable.
Other misc. info.
2000 chevy malibu
Stock alt (HO soon hopefully)
2 12" treo TE
Sundown Saz 1500
07 KIA Spectra
320a Singer Alt
Odyssey Extreme batteries
2 12" Phantom sounds (4.6 cu. net @ 32) - soon to be 2 Atomic ELE
2 Rockford Fosgate T2500bd-CP
Zapco Z150.2
Front comps soon to be Hertz HSK
Pioneer 80prs
Second skin deadener throughout
I'm no expert, but as long as the exposed wire at the ends isn't close enough to arc then you're fine...and I only know this from experience, as I've arced shit before LOL. I might just do the longer distance though to be safe if you have the wire, maybe a post a picture so we can see.
97 Suburban
8 custom PSI Platform 3 18's
Somehow I knew I was going to feel like an idiot after this was answered. Thanks guys.
Everything will be shrink wrapped and no possible way to arc.
07 KIA Spectra
320a Singer Alt
Zapco Z150.2
Pioneer 80prs
It is literally connected to the battery neg terminal. Turned out great. I cant believe the difference it made! I cleaned up and sanded all factory grounds I could find along with the addition of my new wires. ZERO light dim and only dropping from 14.1 to 13.4 in the trunk with the volume about 10% higher than I was able to play before and it sounds way cleaner also.
07 KIA Spectra
320a Singer Alt
Zapco Z150.2
Pioneer 80prs
I'm glad its working out, but the purpose of the alternator case ground is to improve the return path of your electrical system. The alt case ground should connect to chassis, and from same spot connect your big 3 battery ground. That is straight from Tony C. (CE Electronics).
  • Who's Online   0 Members, 0 Anonymous, 682 Guests (See full list)
