You would most likely be fine on just battery power (your upgraded plan). You would just have to give it a rest period after full tilt play to allow the batteries to recharge a bit during constant play.
Also look at grayta's build here his is a 2012 focus running over 2k total with subs and comps. From what I'm told by him the factory focuses come with like a 150amp PCM controlled stock alt.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
wut. my 14 focus ST comes with a 150. iirc the regular focuses come with a like 90 amp. i have to double check the documentation i have.
From what he told me yes 12 comes with 150amp if I remember correct.
141 on music.
141 on music.
150a stock alt? That must be nice.... There must be a reason for it though. Why would they give you all the extra amperage if it wasn't to be used for something? It would be cool if you had an extra 80-90 amps to play with! You could definitely get by with the two battery upgrade and be fine...
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
  • Who's Online   0 Members, 0 Anonymous, 515 Guests (See full list)
