Which Kicker 12" subs?
MaxStanden
Do I want to wire the Dual E15's and SQ1200D to (parallel/parallel) = 1 ohm load or (series/parallel) = 4 ohm load? also what guages of wire do I want to use and what fuse?
gone whippin
You are gonna wanna wire your subs down to 1 ohm. That's where you will get the power that the subs require.
As for power wire, you need to get a minimum of 4 gauge to run the amp. That is the biggest wire the amp will accept without using an adapter. If you decide to go with 4 gauge I would suggest http://www.sonicelectronix.com/item_9894_Rockford-Fosgate-RFK4I.html due to its good price and great wire. You will have to pick up some speaker wire using this kit, but that's not too hard. Hit up your local audio shop for 10 gauge. Unless those subs have some massive tinsel leads, you wont need more than that for speaker wire. If you do decide to buy for future builds, go with at least a single ought or 0/1 gauge like http://www.sonicelectronix.com/item_45055_Belva-BAK02.html and get a pair of 0/1 to 4AWG adapters like these ones http://www.sonicelectronix.com/item_46119_Stinger-SPT521-Chrome.html?from=3 from sonic.
I can say that you are going to want to build for improvement. You are going to love those subs now, but sometime in the future, you are going to want more. Its an addiction. A beast that needs to be fed. Welcome to life as a Bass Addict.
Go sky high. Great guy to deal with and everyone loves his wire. Doesnt rape you on price either.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
  • Who's Online   0 Members, 0 Anonymous, 3203 Guests (See full list)
