New Components & Amp in, Nasty humming noise
KickerKid58
Just finished a lengthy install of some RF punch components in each door powered by a RF400.4. Went to give it a go and heard a nasty humming noise once i turned everything on. (even with the gains ALL the way down) Is this some sort of ground isolation problem? I have the second to best Stinger 4ch. RCA's so I don't think the problem is there. Ran all new 14ga SHCA speaker wire. Just really bummed to put 20+ hours into this and have it not work right. :help: Anyone have a clue as to what the distortion could be? I shot a quick vid to give you an idea of how it sounds after turn on.
Andrew
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
Just because you have good RCAs doesn't mean they wont have a factory defect. Did you try a different set just to see? Also try a different source, as in, connect an iPod to the amplifier and see what happens.
Eliminate as many factors as possible.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Tron, I tried the iphone and saw a huge improvement, however if I paused it, I still got a faint hum.
On another note after 30sec or so of playing off the iphone, the signal just appeared to stop, iphone still playing but no sound :unknw:
And the RF400.4 and sub amp are connected to my battery in back which has a + & - run to the front. I'm waiting on lugs in the mail to ground the back batt to the frame atm..
edit: and yes Big 3 done
double edit: ill have to go buy a cheapy rca from menards and check from the h.u. to the amp i guess
2 DC Level4 12"
RF Prime 400.4D
I find its best to start front to back. I had this issue and I fixed it. The head unit ground was the culprit in my case. Try bypassing the factory ground for the heat unit and ground the head unit direct to the frame up front sanded down to bare metal. In my Mazda there is factory grounding bolt on the passanger side kick panel. Not sure in your vehicle I would try that before spending more money.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
I actually got to work a bit early and had some time to tinker and noticed that while the source was set to the cd on the hu, while muted, the humming was still present but when I paused the cd the humming reduced significantly. So it has to be something with the hu. It sounds like that^^^ may be the issue. I'll try and replace the ground tm morning before work and see if there's any difference. Thanks!!
2 DC Level4 12"
RF Prime 400.4D
So i put an extra 14ga ground to some framework behind the head unit and had no effect :(
Any other ideas? I'm trying to think if my extensive wiring harness has anything to do with it.
http://www.carid.com/2006-jeep-grand-cherokee-stereo-installation/axxess-rap-retention-7833753.html
Like i said above when i pause the CD it stops so it has to be something with the hu. Not sure what though...
2 DC Level4 12"
RF Prime 400.4D
So you left the same ground that was giving you issues connected and tried to add another one?
2010 Mazda 3s 2.5L
Knu OFC 1/0
What brand of HU?
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Yes, I'm not too sure how the whole ground isolation problem works... Does it deal with too many accessories tied to a single insufficient ground?
But I just removed the ground within the adapter harness leaving only my new ground strait to the hu harness. Still no change.
And radio is a Pioneer AVH-X4500BT
2 DC Level4 12"
RF Prime 400.4D
  • Who's Online   0 Members, 0 Anonymous, 1263 Guests (See full list)
