RowdyMoody Posted March 28, 2014 Report Posted March 28, 2014 I just got my wire for my big 3, I have my route planned for alternator + to battery +, and for battery - to chassis. I may be blind but I am having a hard time finding a good spot on the engine block for my engine to chassis wire. What I would like to know is if I can use the alternator mounting bolt as my engine connection. Can I run the wire from my alternator mounting bolt to the chassis?
hdorre Posted March 29, 2014 Report Posted March 29, 2014 For my neg, I did block to chassis, and chassis to batt - The bolt I used was my alternator bracket mounting bolt, because its an M12 (pretty beefy) and mounts to engine. As always, just sand first. Good luck.. You got this shit On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
RowdyMoody Posted March 29, 2014 Author Report Posted March 29, 2014 Cool thanks man, I went ahead and did this and everything seems to be well. Except that now that I have done the big 3 my amp is cutting off if I play it loud, and it seems that my lights are dimming more. I backed off my gain a little bit to remedy this for now. Could it be that I am getting worse dimming and amp cutting off because now that I have done the big 3, the amp is able to pull more power which is too much strain on my alternator and battery to handle?
bigmizzle99 Posted March 29, 2014 Report Posted March 29, 2014 I just got my wire for my big 3, I have my route planned for alternator + to battery +, and for battery - to chassis. I may be blind but I am having a hard time finding a good spot on the engine block for my engine to chassis wire. What I would like to know is if I can use the alternator mounting bolt as my engine connection. Can I run the wire from my alternator mounting bolt to the chassis? Yes!!!!!! Absolutely. In fact, that is how you should do it. Camaro SS Build Altima build 2.0 Altima build 1.0
rockFord_Expedition Posted March 29, 2014 Report Posted March 29, 2014 It can vary from vehicle to vehicle. In a nutshell, you need to make sure everything has a direct path to the chassis. battery(ies), Engine, alternator case. A lot of people say "well my alternator is grounded to the engine and therefore it's connected to the chassis" which is technically true, but since electricity follows the path of least resistance, a direct run from alternator case to chassis makes things more efficient. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
