Dual chamber dual ported
A 6th order?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
So basically two boxes built together? Yeah they are fairly popular. They work well.
ok thanks. The box come with the subs and I didn't plan on using it but I might try it out now.
Yeah give it a try and see how you like it. If you don't then your next step is to build yourself a good box. They are DDs, they will probably sound good. Also placement is something to think about. If at first you feel like its lacking, change the position of the box. Sometimes the difference is amazing.
The only other down side is port efficiency
It is way down
So you have 2 ports 15h x 3.5w x 26.75 @37hz
That's the same as a single port 15 x 7 x 22.5 @37hz
Differance is port efficiency
The first has 74" x length of 26.75" =1,926
Where as the second common chamber
Has 44" x 22.5"= 990
So the efficiency of the port is a huge differance
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
