Rehawk1 Posted March 30, 2014 Report Posted March 30, 2014 I have a 2001 silverado with back seat out, I have 60"x46"x26" tolay with any ideas?
john253a Posted March 31, 2014 Report Posted March 31, 2014 no way 33 or lower, tune them higher, like 37hz unless you require it that low for your music prefances kicker recommends 38-40hz for that sub
ally Posted March 31, 2014 Report Posted March 31, 2014 I always tune my enclosures to 34hz I can play almost all music down to 20hz up to about almost 80hz
ally Posted March 31, 2014 Report Posted March 31, 2014 Joe x will build you a box design he did my 12inch box tuned to 34 2.5cubic feet
ChevyBoy95 Posted March 31, 2014 Report Posted March 31, 2014 no way 33 or lower, tune them higher, like 37hz unless you require it that low for your music prefances kicker recommends 38-40hz for that sub lol, and they perform fine tuned low. I would do...... 22H, 23D, 60W Double baffle facing front of cab Port on the drivers side forward, 7.5in wide, 20.5 tall, 20in long. Would be 11.6 cubes tuned to 32.5Hz or so, with 13.2 per sq in Tune the sumbitches to 28 if you want. Only issue I see if that they have a somewhat weak suspension. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
john253a Posted March 31, 2014 Report Posted March 31, 2014 no way 33 or lower, tune them higher, like 37hz unless you require it that low for your music prefances kicker recommends 38-40hz for that sub lol, and they perform fine tuned low. I would do...... 22H, 23D, 60W Double baffle facing front of cab Port on the drivers side forward, 7.5in wide, 20.5 tall, 20in long. Would be 11.6 cubes tuned to 32.5Hz or so, with 13.2 per sq in Tune the sumbitches to 28 if you want. Only issue I see if that they have a somewhat weak suspension. have you ever ran this sub or build boxes for 1 a low tune in a small box will not do them justice nore will it play into the upper hz 3 x 15' in that box will require some mid bass driver to pick up where they fall short and i never once said they won't play low, i asked why "unless" you music preferences require it, did i not? i had my own single in 7net (not 11.6 gross) 90sq" of port at 37hz on 1k and it played down to below 30hz with no problem, all you need to do is set up your subsonic propley, i had a -3 @32hz and -24@24hz and it waserent the first and only box i built for it, i build several from 30-45hz and that seemed to be the best overall result playing music how much power are you feeding them idd aim for 250sq" of port, (not 150 like^) and 3" all round sub up port side or sub up port front unless you happy to wall it, witch i would as a 3" all round box will take all that 60x46x26 to give you 18net with 250sq" of port
ChevyBoy95 Posted March 31, 2014 Report Posted March 31, 2014 no way 33 or lower, tune them higher, like 37hz unless you require it that low for your music prefances kicker recommends 38-40hz for that sub lol, and they perform fine tuned low. I would do...... 22H, 23D, 60W Double baffle facing front of cab Port on the drivers side forward, 7.5in wide, 20.5 tall, 20in long. Would be 11.6 cubes tuned to 32.5Hz or so, with 13.2 per sq in Tune the sumbitches to 28 if you want. Only issue I see if that they have a somewhat weak suspension. have you ever ran this sub or build boxes for 1 a low tune in a small box will not be do it justice more will it play into the upper hz 3 x 15' in that box will require some mid bass driver to pick up where they fall short i had my own single in 7net (not 11.6 gross) 90sq" of port at 37hz on 1k and it played down to below 30hz with no problem, all you need to do is set up your subsonic propley, i had a -3 @32hz and -24@24hz and it waserent the first and only box i built for it, i build several from 30-45hz and that seemed to be the best overall result playing music how much power are you feeding them idd aim for 250sq" of port, (not 150 like^) and 3" all round sub up port side or sub up port front unless you happy to wall it, witch i would as a 3" all round box will take all that 60x46x26 to give you 18net with 250sq" of port Yes i have, wouldnt be commenting if i hadnt, it doesnt need that much room period (if you needed 7 cubes for a L7 15, you needed more power). That's all im going to say, im out. Good luck op, looks like you got the master of kicker here to help you. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
