Where do I put em?
How do I know where to put fuses when I'm hooking up my system? I'm gonna be running two batteries and still need to do the big three but not sure if you need a fuse on that? I've never hooked up a system before but I've been looking a lot of stuff up and doin my research lately lol but any pointers or any good tutorials you know of would be greatly appreciated!
fuse as close as you can to each battery, within 12 inches or so. and it is a good idea to fuse between the alt and batt
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
The front and ground batteries need to be grounded. It may be easier to ground the back batteries in the back and also save a little wiring. I did and have two runs from the front to the back for ground and also for power. fuse between the alt and battery is a toss up. I didn't. Reason being is that take the fuse out, the wire will get power still from the alt and the battery so didn't want to spend the extra money on two fuses since I have two runs from my alt to battery
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
What I do on cars like ours is run a ground for the rear batt from the front batt. We don't have a traditional frame so I prefer to do it that way, you can also ground the rear batt to the floor, I just don't trust it. Make sure if you do to remove all the paint from where you attach the ground. Front battery already has a ground but you will upgrade it doing the big 3.
CARS
Any wire that touches the positive post of a battery should be fused within 18" (of wire length not actual distance) or so from the battery. Many people do not fuse the charge lead between the alt and the battery, which is a whole different topic.
So for example, if you have a rear battery, you will have a positive wire coming from the front battery or alternator connected to rear battery and then another wire coming from the rear bat to your amps. If the run goes from front battery to rear battery it should be fused twice, once near each battery. The wire coming off of the rear battery should go to either a fused distribution block or be fused It's self.
Just a quick sketch but is this right for 1 run with 2 batteries? Including big 3.
Edit: with a ground coming off the amp as well just forgot to draw it.
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
