never knows best Posted April 4, 2014 Report Posted April 4, 2014 the hu x-over points and slopes are set (exact) the dials on the amp arent.... and they could be used in conjunction to create different slopes (ie- set both to 60hz with 12db slopes to create 24db slope) op- set the hu x-over like i said, you can then tune on the fly instead of getting to your amp if you want to tweek something-
vw passat Posted April 4, 2014 Author Report Posted April 4, 2014 hope this is the last question on my hu I set rear and front @ 60hz with 12db slope and I don't use the hpf on my amp. I leave it at hpf from my amp or @ full? and with 60hz the tweeters are going to work properly? sorry im asking but I don't know nothing on this things thanks
finkster Posted April 4, 2014 Report Posted April 4, 2014 Set it to full on the amp. The crossovers that are wired between your speakers and amp already separate the correct frequencies going to your tweeters. Also, never knows best. Good explanation. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
never knows best Posted April 4, 2014 Report Posted April 4, 2014 60hz on hu. 18 or 24db slope everything on amp off passive x-over need to be used!!!
vw passat Posted April 4, 2014 Author Report Posted April 4, 2014 when u say everything on amp off it will mean I set it on full from the amp instead of hpf or lpf? yes I know that he is giving me a great explanation
never knows best Posted April 4, 2014 Report Posted April 4, 2014 yep- and dont forget there should be a switch on the physical crossover. it will have three positions. turn it to -3db. if the problem persists turn it to -6db.
vw passat Posted April 5, 2014 Author Report Posted April 5, 2014 NEVER KNOWS BEST you gave me a great information that nowhere I was going to find it. the last question even the amp of my sub can do the same put the freq all the way up instead of make it 80hz on my amp and use the hu freq ? cause on the hu x-over there is rear, front (hpf) and sub (lpf). thanks sir
