help with box 3 15 l7s
600-700 rms to each sub going to be enough? Just figured get 2 amps run 2 off 1 and 1 alone... There all 2 ohm subs so amp is 1 ohm stable but will be about 1.3 with all three...correct me if I'm wrong about anything new to this basicly..
hmm nah bad idea, just get an amp for all 3
2 Soundqubed SQ1-2200D
1 Soundqubed Q4-120
4 American Bass VFL 65MR
2 American Bass HD 15's
2 American Bass MX-250T
2 American Bass MX-252T
4 XS Power XP950
Tons of Sky High Car Audio Cable
"Do a proper install, something your happy with, Fuck everyone else......
improve in time, where you can..... its not rocket science..."
bad idea..... just keep it simple. 1 amp since you are new, and even a veteran wouldnt do 2 amps like that, if you do more than 1 bass amp, they are ALL identical amplifiers for good reason.
I would still personally only do 2 ported with that much room, you can make 3 work, but it will be on the small side. If you only run 2, get a nice 1 ohm load on a 2kw amplifier, have a proper sized box, like 8 cubes or so for 2, it will be pretty damn loud for a beginner set up so to speak.
one quick ?, does that 35 put you at the hatch, or is there like 5+ in of clearance between that 35" figure and the back hatch?
So here's some feedback, on the amp I would recommend to get a 3K amp and wire everything in parallel for a 1.33 ohm final load, there's 3K Hifonics amp but if you can get something else that's better.
On the box you would need 34D + 5" port clearance to use the suggestion below (but can be changed a little, maybe to 32 + 4 if necessary):
he doest want over 18h....
2 ohm coils in series subs in parallel is still 1.33 ohm final load, if you have 34D + 5 and you don't mind the box dimensions then you are good to go.
So decided I'm going to have guy from best buy make and install next friday and carpet for $80..order cadence %100 copper 0 guage not ofc but hopefully do job any thought? Be doing big 3 Friday also but with stinger 0 guage on stock battery and alt till can afford upgrade hoping will help...I looked into 6x8 kickers are $60 with build it tweeters cheap but ok? If not can you give few options of cheap 6x8 idk if should have tweeters built in or now
  • Who's Online   0 Members, 0 Anonymous, 3403 Guests (See full list)
