touchet.seth Posted April 2, 2014 Report Posted April 2, 2014 Im trying to hook my moms system back up in her 2005 chevy extended cab. Im having a problem because I hook everything up properly except the amp doesn't turn on. I know that the amp works because Ive used it in my truck before. I have the remote wire going to a ignition fuse under hood because she has a stock radio (ive had it hooked that way for 2 years and it worked) but now I think its not getting power. I cant tell if the wire is bad or if the fuse is bad that im connecting it to. I know that Its a very old wiring kit that she had in her truck and I just used it instead of getting a new one. I just want to see what everyone thinks is the problem because I can change or fix anything that I need.
BZRK_J Posted April 2, 2014 Report Posted April 2, 2014 You could always replace the fuse and check the ground and maybe wire the remote to a different fuse?
Kyblack76 Posted April 2, 2014 Report Posted April 2, 2014 Get a meter time. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Tarball Posted April 2, 2014 Report Posted April 2, 2014 Get a meter time. Or even a test light Try jumping the poet to remote to see if it powers on. That should point you in the right direction. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Rich Schenk Posted April 2, 2014 Report Posted April 2, 2014 Get a test multimeter and start checking your wiring. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
