Found this soldered to the rear tweeters in my girl's car. The fronts have different looking capacitors on them as well. Is this just a capacitor or is it an effective replacement for the crossover? Thanks!
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
ITs a type of capacitor don't know why it is there but that's what it is.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
For an 8Ω load that 3.3uf capacitor should give you a 6dB/octace hi-pass filter @ 6kHz.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
sweet, so it sounds like I'll need to take these out and replace them with the crossover that came with my components. Last question here: there's already 2 separate sets of wires, 1 for the tweeter and one for the mid-woofer. My crossovers only have one set of inputs and then outputs for each the tweeter and mid-woofer. Should I just combine the existing 2 sets of wires running them into the crossover to make things work correctly? Thanks guys
You running off an amp? What size are the wires? I personally like to run new wires and leave the factory stuff just out of the way. Easier to put back if you ever need to and you know exactly what us happening.
Running off the factory amy, wire's I'd say are around 14-12 gauge, seems like they'd fit just fine
  • Who's Online   0 Members, 0 Anonymous, 2597 Guests (See full list)
