How Low Should Voltage Drop On XS D3400 During Storage?
I fried batteries on a bit higher than that voltage. It's really up to you how much of a big deal you want to place on it. I've cooked my batteries, others have run for years without issue. YMMV
And as for the combo of things making a draw: Yeah it's entirely possible for that to drag down your resting voltage a bit. Little draws add up. I noticed mine changed when I got an aftermarket alarm
Interesting on the alarm, but it does make sense as it is constantly monitoring sensors, etc., ... especially if you had perimeter, & if you had it activated.
I suppose the only question I have left, & I thank you greatly for what you have shared already is: What can I do if I want to tune the charging voltage down a little? ... & right along with that, ... within the next month ... well, probably my Memorial Day Weekend project ... I will be adding a D975 to the trunk ... when charging both BATTs, I would probably want the higher voltage, no? I guess I do not know how the voltage(s) are going to go/react once a second BATT is added to the system. I am going to take both my front POS & NEG - which run to the back anyway, & take them away from the DIST BLKs for the amps, & put right on BATT, then run 1/0 POS & NEG off the D975 to the DIST BLKs for the amps. That's how I should do it, right?
PS: I have to admit that I also had to look up "YMMV". Ugh, ... I am too old!
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Number of batteries doesn't have any effect on charge voltage
As far as reducing: call up your manufacturer and ask for either a lower voltage regulator or just go to a full external reg
Got it.
Zeke
'14
Pioneer FH-P8000BT
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
