Kyblack76 Posted April 7, 2014 Report Posted April 7, 2014 I dont run one..... not a low nor a high... my box does it magically for me.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Krakin Posted April 7, 2014 Report Posted April 7, 2014 The 2500BdCP has a 24dB/octave (3rd order butterworth) low-pass filter and a 12dB/octave (2nd order Butterworth) infrasonic filter. This is from the spec sheet online. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Skax Posted April 7, 2014 Author Report Posted April 7, 2014 The 2500BdCP has a 24dB/octave (3rd order butterworth) low-pass filter and a 12dB/octave (2nd order Butterworth) infrasonic filter. This is from the spec sheet online. im confused lol so which one should I do ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Kyblack76 Posted April 7, 2014 Report Posted April 7, 2014 What you SHOULD do, is based on your build.... Start somewhere... Like 80LP and 12 slope.. Then fuck with it.. there is not a single person here, that can tell you what is the clear cut bro?!?! SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Skax Posted April 7, 2014 Author Report Posted April 7, 2014 What you SHOULD do, is based on your build.... Start somewhere... Like 80LP and 12 slope.. Then fuck with it.. there is not a single person here, that can tell you what is the clear cut bro?!?! yea my question is how do I know which slope I have ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Krakin Posted April 7, 2014 Report Posted April 7, 2014 You don't have an option, that's just what they are. They do different things, as well. The Low-Pass will block off everything above the frequency you set it at. The infrasonic will block the frequencies below what it is set at. A typical way of setting the infrasonic is to set it 1/2 an octave below the tuning of the enclosure. One octave up is exactly twice the frequency being look at. Ex: 1 up from 40 Hz is 80 Hz. 1 down from 40 Hz is 20 Hz. 1/2 down from 40H Hz would be 30 Hz. A common place to set the Low pass is 70-100 Hz. Much over 80 Hz starts to throw staging off. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Skax Posted April 7, 2014 Author Report Posted April 7, 2014 So if I turn the infrasonic on it makes it 24? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Krakin Posted April 7, 2014 Report Posted April 7, 2014 Don't worry about the order of the crossover (slope) You have no way of affecting this other than buying another amplifier. What you can do is set the Low pass filter. Set this at 80 Hz and then mess around with it slowly to see what you like. I don't have experience with your amp, but from the looks of it all you can do is turn the infrasonic filter on and not change the frequency it affects. Rockford has already set it inside with their circuitry. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Skax Posted April 7, 2014 Author Report Posted April 7, 2014 So infrasonic on and start at 80hz and adjust slowly 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Krakin Posted April 7, 2014 Report Posted April 7, 2014 Yes Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
