final impedance?
m720bos
What model power series amp is it? yes you should wire to 2 ohm as those amps are not .5 ohm st
its a T500-1bd the black one that looks the same as the newer bdcp
I powered 2 subs at .5 for months and it never even got hot
If it works then it works but if at some point it suddenly cooks, you will know why, guys like you feeling that you are lacking output should look into upgrading.
Were the previous subwoofers also D2ohm? Saying that you wired previous subwoofers in the same way as you plan on wiring these does not matter if they were not the same vc configuration.
04 Honda Accord LX Sedan
Kenwood Excelon X998
XS Power D3400
XS Power D1200
Singer 275A alternator with factory bypass
64 sqft SecondSkin Damplifier
Build to be decided
:peepwall:
yea they were too.... thats why i said that that they were wired the same....
ye i definitely dont want to do that... i have another one of the same amp and i plan on running each sub on its own amp but current circumstances are to were i cant.... the amp is in the pawn shop cuz i had an emergency blah blah blah and blah... but yea
You sure? Funny it didn't go into protect.
And for future reference: http://www.the12volt.com/caraudio/woofer_configurations.asp
i used to run a fosgate at .5 and took it like a champ.. it was when i didnt know anything about audio.. stock 125a alternator a 1 farad cap and a wet cell and the amp still gave no fucks..
edit: it did went into protect a few time though the gain was maxed out what you call 100% gain up.. i guess that was the reason it went into protect but im sure if i was to set gains properly it wouldnt have
  • Who's Online   0 Members, 0 Anonymous, 3430 Guests (See full list)
