Exactly what does "ticking" sound like?
axevon
Just a short, possibly unfortunate question:
I bought a FI SSD 12 during the black friday sale last year and just now got around to doing some testing.
Both coils read the appropriate 1.7 ohms and I don't think I heard coil rub when pushing down (I don't exactly have any experience with what the rub feels like)
Anyway, at high excursion I hear a sound that almost sounds like air escaping around the sub exactly at the frequency of the tone. At first I thought it was the fault of the gasket that doesn't perfectly seal against the box, as their is a tiny sliver of space when fully tightened down. I know the box isn't leaking because it never made the sound with the Soundqubed sub.
Is this the infamous "ticking" I hear of that causes a sub to be sold as "B" stock such as the ones in the Sundown Audion Garage Sale?
Is this big enough of a deal to contact FI about?
How much damage would this cause if it was the worst case scenario?
Thanks!
Dorm room setup:
SQ SDC2.5 12" @ 8 ohms
Klipsch 300 watt home theater sub amp
Marantz 1030 amplifier
Future car build:
Audio Technix 1200.1d
Fi SSD 12 w/ cooling and flatwind coil
6th order dual reflex enclosure
Id think ticking to be a mechanical sounding noise rather than an aiiirry noise if that makes sense. Make sure that the surround or dustcap isnt lifting or doesnt have any holes. Make sure the screw holes are all fully tightened. Sometimes ppl rotate subs and make a new set of screws holes every so often after mounting and unmounting a bunch of times. If that were the case maybe air is getting out from those.
Id be interested to see what others say, but id think ticking to be mechanical clanking or something
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Ticking? Coil rub sounds crunchy. Its pretty unmistakable.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I would check loose screws...Those can make a chirp noise when loose...in for what other say also
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Ok so if its a form of coil rub, then you should be able to feel it likely. Push center on the sub real slow multiple times up and down and you should be able to feal the scrapage. but i doubt FI would send you a sub with coil rub. B stock would be cosmetic stuff scratches etc but 100% working.
Setup:
Xs D3400/ Xs XP3000
The dust cap happens to be carbon fiber so would that make it more prone to leaking than a conventional cap?
Well it wasn't exactly a chirping noise but that does sound closer than crunching ... I don't think it's the screw's fault since the other sub was fine but I might redrill if nothing else works
Dorm room setup:
Future car build:
dbl post...
Dorm room setup:
Future car build:
I definitely trust Fi with their products, I just want to make sure there's no damage being done. I don;t feel anything and definitely don't feel any scraping so I thought that would eliminate coil rub.
I have always thought coil rub and "ticking" were two different and completely unrelated things...
Dorm room setup:
Future car build:
I mean trying putting pressure with your hands on certain parts. not real hard or nothing but if you your thumb over a screw hole or two and the sound changes a bit then thats a clue. Or if you apply very slight pressure to the cap or push down on the gasket etc. Any gap larger than a mm from gasket to box is a leak imo. put tape from the gasket to the box like sealing the sub. if it sounds better itd be a leak also. obvi if you feel air then yea its a leak.
Setup:
Xs D3400/ Xs XP3000
I agree. I thought a leak was the culprit because it sounds airy but at the same time it sounds more substantial. I will try putting tape around it to see if that helps. Any suggests for kinds of tape and/or would silicone caulk be a good sealant?
Dorm room setup:
Future car build:
  • Who's Online   0 Members, 0 Anonymous, 3430 Guests (See full list)
