Box Size for Power.....?
bgowdy31
Make a decently sized efficient box, and run them at ~800-1000 apiece daily, only if you have clean power.
them burping capabilities tho
2001 Civic LX Sedan
Pioneer DEH-7500HD
Big 3 in 1/0 Knu CCA
Rockford P500-4
RF Punch P165-S in doors
RF Punch P165 in rear deck
Front doors deadened with Damplifier
Next
SQ's new HDS208 8" in a T-line whenever it FINALLY COMES OUT I CAN FINALLY AFFORD IT
:dammit:
Bend over and I'll show ya.
how is it 2 days work? half a day at most, i may be an idiot, but im not an idiot.
playing music after rise and voltage they will only be seeing probly 1k anyway
99 HONDA ACCORD EX COUPE
1 American Bass HD15-D1 ~ THE PLAN- ? CUBES NET ~ TUNED 36HZ
SOUNDSTREAM TA1.3K @ .5OHM DAILY ~ STOCK ALT ~ BULLZ AUDIO 1/0
~BEST SCORE TO DATE ~ 95 BLAZER 147+DB 30-SEC MUSIC-BB2400 & 1 HDC3-18 W/STOCK ELECTRICAL~
~01 HYUNDAI SANTE FE ~ 1 DC XL 18 ~ SHARK2500 @ .5 DAILY ~ 145.8 LEGAL~
~2010 FCBC 450 STREET 3RD OVERALL~
~2011 FCBC 450 STREET CHAMPION~
~YOUTUBE SEARCH->bgowdy31 & bgowdy3131~
you hope anyway.
Just to be clear, are you counting on low voltage to save your subs?
lol no, i dont think my voltage will drop more then 1/2 of a volt(from 14.5 to 14v unless at idle) lol. but im figuring ill be rise far enough to drop the power. its 3k before rise and im sure id have atleast 1.5x rise or more
Just do 4.5 cubes. You will be fine with that. A bigger box will require you to reduce power handling so excursion can be controlled.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Low end response will disappear so you can mechanically control your subs with less airspace. Run your subs at rated power, in the proper amount or airspace.
If you need to run more power, get a sub that can handle it. When you start cutting airspace, you'll sacrifice low end response. It's not worth it so you can run more power that the sub will just turn into heat. Heat kills, slowly or quickly.
as far as low end response i dont listen to anything below 34hz, i like mine from 36hz & up.
i have more then 4.5 cubes available, not much more tho lol
ttt
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
