negative runs
I think it depends on the vehicle.
If you are talking about ADDING a front to back - run, no it wouldn't hurt a thing but if you are talking about doing that instead of a proper frame ground in the rear, I say you are better off without it. All depends on the vehicle I guess. Enough front to back runs can be just as good or better than a frame ground in the rear in some instances, but we are talking about a whole lot of wire.
Well the run is already in there and its a 96 explorer. And the way I figured it is that power would travel with less resistance in a wire compaired to a frame. And as it was mentioned earlier I'm gonna swap the neg to a pos. And see the difference. Sucks batteries won't be here till Tuesday
To many variables to say really. Depends on the car, setup, etc etc...
do it and a good solid frame ground then test switching it to a pos run like said. Just see what works best.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
