SundownZ71 Posted April 14, 2014 Report Posted April 14, 2014 Which is better, wiring a 2 ohm sub down to 1 ohm or a 4 ohm sub down to 1 ohm. Or does it even matter
SundownZ71 Posted April 14, 2014 Author Report Posted April 14, 2014 Are you only getting 1 or 2 subs? Only 1 (SA-15)
Noel989 Posted April 14, 2014 Report Posted April 14, 2014 You can't wire a 2 ohm sub to 1 ohm or a 4 ohm sub to 1 ohm Build Log - http://www.stevemead...-cruiser-el-pt/
matt.b Posted April 14, 2014 Report Posted April 14, 2014 You would need two 4ohm woofers to wire down to 1ohm but besides that it wouldn't make a difference
matt.b Posted April 14, 2014 Report Posted April 14, 2014 You can't wire a 2 ohm sub to 1 ohm or a 4 ohm sub to 1 ohm one 2ohm dual voice coil in parallel would bring it down to 1ohm (don't know if that was a typo)
Noel989 Posted April 14, 2014 Report Posted April 14, 2014 You can't wire a 2 ohm sub to 1 ohm or a 4 ohm sub to 1 ohmone 2ohm dual voice coil in parallel would bring it down to 1ohm (don't know if that was a typo)It wasn'tBut you are correct on the first part Build Log - http://www.stevemead...-cruiser-el-pt/
matt.b Posted April 14, 2014 Report Posted April 14, 2014 You can't wire a 2 ohm sub to 1 ohm or a 4 ohm sub to 1 ohmone 2ohm dual voice coil in parallel would bring it down to 1ohm (don't know if that was a typo)It wasn'tBut you are correct on the first part I thought you just made a simple mistake
gr8handogoatness Posted April 27, 2014 Report Posted April 27, 2014 Matt is assuming dual voice coils and noelito's first post was referring to single voice coils. If you have a woofer with 2 voice coils at 2 ohms each you can wire it in series to get 4 ohms or you can wire it in parallel to get 1 ohm. Now I'm sure you probably figured this out so I don't need to say it but a dual 4 ohm sub can be wired parallel to 2 ohms or in series to 8 ohms. If your subs have single voice coil configurations then they are what they are, no flexibility.
