kicker8940 Posted April 18, 2014 Report Posted April 18, 2014 How about if you do subs up port back. 2.64cuft net @ 34Hz
jarrius Posted April 18, 2014 Report Posted April 18, 2014 If I'm correct it would just make the box smaller so she had more space. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
timc31610 Posted April 18, 2014 Author Report Posted April 18, 2014 If I'm correct it would just make the box smaller so she had more space. I'll have to read up on that tonight, it would accomplish several goals. 1. Different and unusual box. 2. Protect the subs and 3. save space. How about if you do subs up port back. 2.64cuft net @ 34Hz I like that, but this stupid SUV has a shelf that will go above the box so that she has somewhere to put groceries and such... It would either rattle the shelf off or make a lot if noise..lol. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
kicker8940 Posted April 18, 2014 Report Posted April 18, 2014 I would think no matter where you mount the subs your gonna get vibrations,unless your worried about the shelf falling and landing on the subs. In which case you could mount the subs on the front of the box,but you won't be able the flush mount the subs unless you increase the height of the box. Actually you might be able to flush mount the subs but it will be real close.
timc31610 Posted April 18, 2014 Author Report Posted April 18, 2014 I would think no matter where you mount the subs your gonna get vibrations,unless your worried about the shelf falling and landing on the subs. In which case you could mount the subs on the front of the box,but you won't be able the flush mount the subs unless you increase the height of the box. Actually you might be able to flush mount the subs but it will be real close. Yeah, I am concerned of the shelf falling causing damage. Does anyone see an issue with what I proposed above, with hte 1/2" piece of MDF with the logo cut out? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
Joe X Posted April 18, 2014 Report Posted April 18, 2014 I don't have a problem with the Torres you posted earlier, I just wouldn't do a flush mount unless the baffle was a little taller.
Joe X Posted April 18, 2014 Report Posted April 18, 2014 You are just going to need some nice grills.
timc31610 Posted April 18, 2014 Author Report Posted April 18, 2014 Joe,how much higher would I need to be? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
LoudBimmer Posted April 18, 2014 Report Posted April 18, 2014 I haven't really seen that many people do subs up port back with 10's. Usually 15's and 18's only. Subs back port back with plenty of port area and it should sound good.
Joe X Posted April 18, 2014 Report Posted April 18, 2014 Joe,how much higher would I need to be? Whatever is enough to do your flush mount comfortably, that's the only reason I pointed that out, if you are fine doing them as in your sketch then just go ahead.
