andrewlicata1993 Posted November 5, 2015 Report Posted November 5, 2015 so did you ever build it. i have been looking for a design that will fit my 96 accord and this tuned to 32 hz looks like the ticket
Frank Seaton-Gilford Posted November 8, 2015 Report Posted November 8, 2015 Closest as possible to your max dims, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Is it possible to do a design for 3-12 L7 for a 04 Tahoe Dim: 48w 22d 20h. SPL GLA1.3400 Amp for now. Thanks
Miguels Posted November 8, 2015 Report Posted November 8, 2015 what is the displacement on that enclouser? solos love larger enclosures. for 12's you would need an enclouser made for 15's never mind i see that its at 5 cubic feet.. they would do better in a 6.5 ft^3 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Frank Seaton-Gilford Posted November 11, 2015 Report Posted November 11, 2015 Hello, is it possible to design the enclosure please? Thanks
Joe X Posted November 11, 2015 Report Posted November 11, 2015 Here is a suggestion, power: to subs rated, subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide: .
Frank Seaton-Gilford Posted November 11, 2015 Report Posted November 11, 2015 Here is a suggestion, power: to subs rated, subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide: . Awesome, so that'll take 2 sheets of MDF to build correct?
LoudPackRacing Posted November 13, 2015 Report Posted November 13, 2015 Yes two 4x8s. I wanted to know what box design software you were using?
LoudPackRacing Posted November 27, 2015 Report Posted November 27, 2015 Here is a suggestion, power: to subs rated, subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide: . Awesome, so that'll take 2 sheets of MDF to build correct?Can you design a box for a fi ssd 15 tuned to 32hz with max demensions being 17.25 height 34 width and 20 depth sub and port forward
Joe X Posted November 28, 2015 Report Posted November 28, 2015 Sure, make a thread mentioning vehicle and amp you are using.
