Who hosts SMD's Web server? I would like to know because I'm looking for some good hosts for my new upcoming website I'm working on
Edit.
I think it is http://softlayer.com. Can anyone confirm?
Dont worry about whp hosts smd and find a host who is going to wprk for you.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Get a VPS or dedi instead of buying shared. It is much better
What are you hosting?
I personally buy domains from offshore parties so DMCA has no control
I wouldn't call the host that "good"...
But there are easy was to find this out, just to the research.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
This is a good idea. You can get a takedown for pretty silly reasons nowadays.
EDIT: Do a WhoIs lookup. It's public information. There are services you can use where they register it for you so when someone does this they get generic info instead of your info. Also worth looking into.
Only thing with off shoring is when it comes to privacy laws and things like that. If you arent worried or hosting pii its not a concern. Its a disaster if you do. Not to mention your support will likely suck balls if its ever needed
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I agree that offshore comes with a higher price and sucky support but you shouldn't need support besides incase of DDoS.
If that is the case, rent a small VPS FROM OVH and get the 170Gb protection and run it as a reverse proxy using Nginx for your other server
Right and starting off you arent exactly goinf to be a ddos magnet but these are things to consider. I cringe at the thought of calling in support cases anymore.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
