static noise when bass hits wtf??????
Blake Farrar
Do you have bass boost on (on) your amp
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
It'd help to know more about your setup. Speakers connected directly to HU, or amplified? What equipment? Details on said equipment so we don't have to Google every part number for info. Ect.
Probably also a good time to ask your level of experience, do you have a DMM, ect. so we know what options we have available to help you troubleshoot. Without the right tools and knowledge to use them, it doesn't matter what advice you get if you don't know how to act on it.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Try pounding on your amp with your hand to see if you can get it to cause the problem, if it does then you have an internal amp issue in need of repair, if not then check all your wiring to make sure nothing is possibly loose causing it to short out on the body some place, that includes everything from your speakers to the amps to the H/U, make sure nothing is loose if you tug on it.
Another thing to look into is the wiring itself and make sure it has not been cut or pinched causing it to short out on the body.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Alright so I have a apline HD 148bt no add peakers wired to head unit for my amps I have a CT sounds 125.4 with 2 pwx 8s on channel 3 and 4 and a sundown sa component set on channel 2 and a cresendo compent set on channel 1 my bass amp is a hifonics brx 1100.1 wired to two sundown e12s wired down to 1 ohms and a stock batt with a 220,mechman alt big 3 done in 0guage welding wire ive checked almost everything I could and no I dont have a dmm
  • Who's Online   1 Member, 0 Anonymous, 1088 Guests (See full list)
