WTF HAVE I DONE? :(
You would need to check the remote turn on voltage coming from the head unit just like you checked it at the amp... with your meter. That can easily be done by probing connection between the head unit harness and the wire running to the amps.
I don't see a lot of fruit from that test though, it sound like you blew that circuit in the head unit and since they're not protected, you'll have to grab power from an ignition switched circuit in the car.
how could i go about doing that ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
you can find a wire that turns on and off with the key and use that for your remote. Have you hooked up line from the power to remote on your amp like someone suggested? That will verify that it is infact the head unit remote thats bad.
New build coming........
YouTube:http://www.youtube.c...6?feature=guide
Old Build Log: http://www.stevemead...d-on-the-cheap/
Old Screen name: Redrebel66
no i havent tried that how could i try it?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
So have you corrected your low voltage problem yet or are you still playing down into the 9's?
fixed it. sold the 2500 : :roflmao: until i can run that much power
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
