bass juggernaut Posted April 21, 2014 Author Report Posted April 21, 2014 the subs will be ran on about 7k with badass electrical
alaskanzx5 Posted April 21, 2014 Report Posted April 21, 2014 Add the woofer displacement and it will be around 2.5net each. 2.5+2.5+75sq.inch+displacement = gross. Port width and length is up to O.P. as long as its 75sq.inch ok but port lwnght takes away from net, the 75" of port area does nothing to net volume until you add length to it. Then there is bracing, maybe double baffle, 45s or PVC rounded corners. You don't know what op has in mind. Giving gross volume is misleading. Net volume is far more accurate to estimate. say he decides he want a 5cyft net box with .97cuft of port deisplacent and .4 of bracing and 45s then there is .23 from the double baffle and .4 from subs. You end up with 7cuft gross. Take the 45s out and your say .3 shorter in displacement and he doesn't have to account for a double baffle because he chooses not to go that way. Then he gas a box that is 6.47cuft gross. guess what though if we say he should aim for 2-2.5 net he has a range that is constant no matter what extra things he does or doesn't do inside the box. Its the accuracy of suggesting a giving net volume over gross that matters. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
TRTC360 Posted April 22, 2014 Report Posted April 22, 2014 7 cubes gross sounds about right for those subs. Unless he's running an ungodly amount of power. My friends hdc3 12s and x 12s were both in a 7.5 cube gross box and they got down. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
slowfkncar Posted April 22, 2014 Report Posted April 22, 2014 Add the woofer displacement and it will be around 2.5net each. 2.5+2.5+75sq.inch+displacement = gross. Port width and length is up to O.P. as long as its 75sq.inch ok but port lwnght takes away from net, the 75" of port area does nothing to net volume until you add length to it. Then there is bracing, maybe double baffle, 45s or PVC rounded corners. You don't know what op has in mind. Giving gross volume is misleading. Net volume is far more accurate to estimate.say he decides he want a 5cyft net box with .97cuft of port deisplacent and .4 of bracing and 45s then there is .23 from the double baffle and .4 from subs. You end up with 7cuft gross. Take the 45s out and your say .3 shorter in displacement and he doesn't have to account for a double baffle because he chooses not to go that way. Then he gas a box that is 6.47cuft gross. guess what though if we say he should aim for 2-2.5 net he has a range that is constant no matter what extra things he does or doesn't do inside the box. Its the accuracy of suggesting a giving net volume over gross that matters. Yes you are correct,port length will take from net volume. But the whole point of this thread is more port or more net. Op now that you have told us you will be using 7k rms,7 cubes is to big and will probably have a loss of output compared to 6 gross 2 net. Anyways,like i said. If you choose to keep 7 cubes gross,your still gonna need 75sq inches of port. It is up to you to decide on port length because of any internal bracing ect that you add.
Aj11 Posted April 22, 2014 Report Posted April 22, 2014 if your running 7k i wouldn't go bigger then 2.5 each. ill putting more then rated to my sub but me and another member are planning a box to.help sub excursion so that shouldn't be a problem. if you go to big witj that much power your risking pushing them to far jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
PolishThunder Posted April 22, 2014 Report Posted April 22, 2014 I say this a lot but, i prefer to use software to calculate box size and port dimensions. It takes a little more time to figure out but it takes out a lot of guessing and in the long run makes a much better box if its done correctly.Some software I use and would recommend (all free) is winISD and torres tuning calculator. Using those tools can help you find the perfect box for your equipment and application. (sorry to plug the software like that i just think its the best way to go when designing boxes haha)
bass juggernaut Posted April 22, 2014 Author Report Posted April 22, 2014 thanks for all the input guys i appreciate it
