greezychef Posted April 22, 2014 Report Posted April 22, 2014 could i do 3 sa8's in a box that would have to fit inside 30Wx14Hx16D ported, unsure of proper tuning?
timc31610 Posted April 23, 2014 Report Posted April 23, 2014 After port and sub displacements you will be around 1.8 cf if im guessing correct. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
john253a Posted April 23, 2014 Report Posted April 23, 2014 No 2 yes And 4 yes 3 no unless your happy running a 5" aero 24" long at 42hz
timc31610 Posted April 23, 2014 Report Posted April 23, 2014 2 ported or 4 sealed? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
greezychef Posted April 23, 2014 Author Report Posted April 23, 2014 No 2 yes And 4 yes 3 no unless your happy running a 5" aero 24" long at 42hz guess i could wait and get the x8's and just do 2. they re gonna be rated at 750wrms. and im using a t1500.
john253a Posted April 23, 2014 Report Posted April 23, 2014 The x8 should take that t1500 at 1 ohm on it own no issue The sa8 takes 1k daily no issue Do you have the t1500 yet There a good amp and should do 17-1800rms @1ohm Witch is perfect for 2 sa or X8
greezychef Posted April 23, 2014 Author Report Posted April 23, 2014 yes. im currently punishing 2 Re audio se-x 10's with it on a daily basis. the re's are in a box thats 29x14.25x16 @ 35hz. subs facing rear to trunk the port is on side of box near cabin. its sounds good but i just got a feeling those subs arent gonna last long. after playing them hard they start to smell.
